That doesn't make any sense at all, a parachute obviously won't keep an airplane floating.The proper argument to the plane analogy is, why do they have parachutes??
Sent from my SM-G970U using Tapatalk
If foam didn't make sense, oem's wouldn't waste the money installing it from the factory. They do, so there is a reason.
Sounds reasonable. Judging by the video I think the only thing keeping it on the surface was dry factory foam in the tray.My superjet sank wayyyyy quicker than that. It is however shortened with tray plugs and the tray has a decent leak in it. Landing upside down from failed back flip attempts is all it took
Since we are all over the place here maybe we need to be more specific?
On a smaller hull like some AM you probably don't have enough space to add enough flotation to keep it above the water. And yes, even on a meticulously maintained and built ski things can and do go wrong.
On a full size ski like a Superjet, yes there is enough flotation to keep it on the surface and even with the stock foam they will stay above the water even with the hood off.
Here is an actual sinking test of a stock superjet and it stays on the surface.
Most likely that hulls foam was waterlogged really bad. I did a nose stab one day just effing around, was kinda frustrated. Ski was running bad, Had the hood off trying to see if it was an exhaust leak. Decided to do something really stupid. Like a Nose Stab!!!!!! It bobbed with no issues. But the hull was not waterlogged.At pismo a super jet went down, it was quick, tail up but only just at the sea surface level, it would disappear out of sight then reappear as the sea and wash went by. It went to the bottom in no time...
Even on my own aftermarket ski’s.. had almost sinking happen 3 times... was surprised how little water it took to start over coming my positive buoyancy
