Super Jet Help: Stripped Factory headpipe to manifold bolt threads
Waternut
Customizing addict
Macon, GA
IMO, if you're going to helicoil or timesert it, you might as well go 3/8-24 threads. The helicoil/timesert kits are cheaper, the bolts are cheaper, and everything is WAY easier to find. 5 - 2" long socket cap bolts in SS are $6. http://www.mcmaster.com/#92196A365. Even the M10x1.25 socket cap bolts sold on here (which are nice) are not long enough IMO. I stripped the bolts Jetmaniac sold a year or so ago because they weren't engaging enough threads with my helicoils. Here's the kit if you can't find it locally. http://www.amazon.com/Helicoil-5528...FUOC/ref=sr_1_5?ie=UTF8&qid=1334667627&sr=8-5. To each their own but this system is the holy grail compared to the M10 bolts IMO.
edit: If by some stroke of bad luck or poor judgement (my particular problem) you happen to find yourself needing or wanting to replace helicoils that aren't perfect and you screw up that hole. You can buy the 3/8-24 BigSerts which will work with your massive screwed up hole.
Thanks for all the replies guys, I really appreciate it. I'm glad there's a relatively easy fix, I'm just still miffed that I've got to pull everything apart again!
You know the helicoil can be done with manifold attached to motor and the head pipe can twist on the loosened coupler out of the way right ?
tomski
X
LHC
A long bolt with a nut will work for a temporary (beach) repair for that hole. Or at least until you buy the repair kit.
Waternut
Customizing addict
Macon, GA
The underlined part sounds like more effort than just pulling it. My old SN came with one of the pipe bolts attached to a nut on that inboard hole and it worked for a long time. If you do helicoil it with the manifold attached to the motor like I've always done, I would highly recommend putting tape over the exhaust hole so metal shavings don't go down the engine.
BruceSki
Formerly Motoman25
Long Island
check the length. There are three longs and three shorts. You need the shorter ones I believe. Match them up to the factory pipe bolts.
I've been doing that for at least 3 years. Never had a problem. If you grind down a flange nut just slightly it will hold itself against the surrounding surface while tightening. Actually think it is more secure this way as it sandwiches the manifold and headpipe together at a weak point.
tomski
X
LHC
Might as well use a carriage bolt next time.
oem bolt isnt stainless
ive seen several of them rust
1st time i had threads fail i removed a bolt off my trailer and ran it through then put a nut on bottom
was a real pia but saved my day at the beach
i was a hr away from home
and no helis
time serts are the way !
jason
Please consider applying (blue) loctite to the threads of the 3 fasteners and you wont compromise the threads in the manifold from the beginning. The manifold is made of aluminum. Your cap screws are not. Galvanic corrosion will eat the fine threads unless you use an inhibitor like loctite. Nice people don't use grease when screwing into aluminum- there is one exception that comes to mind: the M8 cap screws which fasten the bed plates to the rubber mounts. They should have grease or anti seize applied to enable future disassembly. (the lg. f/w and their length makes them "springy" enough not to loosen.)
AJs
Mn
Have same issue with my thread. Is there an extended length insert to cover the entire hole length or are people running the standard 10-15mm length inserts?
Wondering if thats even necessary, just trying to get the best fix so no issues later
