Freestyle help! prop stuck in mag pump
I don't know if this is going to make sense.
if your holding the impeller tool in the vise and wrenching on the spline tool hanging out of the vise on the end of the shaft isn't it still left loosy - righty tighty.
if your holding the drive shaft spline tool in the vise and wrenching on the impeller its left tighty -righty loose.
I've seen a # of people be told its a left handed thread and not understand exactly what to do. good luck with getting it off.
Penken
whoomp there it is!
Umeå, Sweden
correct.
it explains it easy in the manual. turn the impeller clockvise to remove it. i dont think that it could be missunderstod.
i had a prop stuck in my magpump yesterday. tried to get it of. no go. built a superduper mega tool and it came lose no heat. 5 foot bar on a foot long wrench.
ill post a pic of the amazing tool. can be bought on TV shop soon!
Penken
whoomp there it is!
Umeå, Sweden
you clamp it in a vice on the driveshaft. it holds the splines and also clamps the shaft removing shaft flex in the side directions and you only need to use one wrench instead of two.
