Air Gramps
Air Gramps
- Virginia Beach
Got a problem.....
701 SJ running bad...
1) new plugs - no change
2) pulled front wire off, runs the same (1 cylinder) so front cylinder out..
3) Check spark on plug.... Strong spark
4) Plug is wet with gas....
5) compression at 150....
Does the 701 stato fire at both 0 and 180 on both plugs OR can I assume if 1 fires the other has to be good.
Can my stato be bad on 1 pickup? Are there 2 pickups?
