Other help needed
montreal
hi what i can do,i got a little rock jamed in my fp head pipe ,try to shake it ,put some air in,water,the rock dont want to came out and its make my pipe hard to tune.........
Pa
hahahahaha what!? that sucks, try using a piece of tube that will fit into the water fitting whole, with the fitting out, tape the tube to a shop vac and get some suction on it. another use for duct tape
the only way this rock would change tuning of pipe is if it was lodged in one of the adjusting screw holes.if that's the case ,it would be easy to grab with tweezers.
ditto if it's near one of the water fittings.
Ohio
And I have seen a rock wedged in to a brass fitting so hard that it was easier just to replace the brass fitting. It was jammed so good that it wouldn't even break up with screw drivers and chit!
montreal
i remove the brass fitting and shake the pipe,whit a flashlight i see in the hole ,there is a big piece of metal,to big to came out of the hole..try to drill it,remove a small pieces,but still another big pieces would come out.........i think thats the reson having trouble tuning the pipe......someday the pipe heat a lot and someday its ok..........
I got glass beads stuck in mine from the powdercoater. Got the mani and headpipe ceramic coated shiny silver/chrome.. I was just gonna leave them...now I think I should get them out damn
I have a hard time believing that's what's making your pipe hard to tune. (Unless the rock is cok-blocking one of the spray holes)
montreal
maybe not have benn able to remove a small pieces,try it whit the garden hose ,turn the bottom adjustement screw.close it and o^pen it it semm to work well,then try the top screw close and open it little by little and works well too...i think its gonna be ok ....i hope
