Filled crossover is SOP
Is your boat propped correctly? If it is too low and you are chasing boats at the lake then you may want a higher prop. Is there anything else that could be causing an excessive amount of drag on the engine? Did you check both the plugs? could there be a pinhole in your return where you are losing fuel out the bilge? I want to say the carb size/maker is not the problem, it is tuning or something else.
