head gasket??
oxnard111
Creative RE Purchasing
I would order another gasket that will fit your bore. I have a head gasket at home that says right on the label "Big Bore Head Gasket 2 over (.5mm)". So I would assume you would need the correct gasket. Just order the other one, and return or keep the one you don't use. If you keep it, it'll come in handy in the future.
W
wydopen
Guest
where did u order that from??..the guys at the shop acted like i was speaking chinese when i asked him similar questions..
oxnard111
I'm not sure... I'll take a look at it when I get home. Nikad85 (Butch) sent it to me to change the head on a old motor that he sold me that was bored .5 over. I'll see if what the part number and manufacturer are when I get home.
W
wydopen
Guest
THANKS!!..i called watcon and they said just measure the bore and the thickness and they can get e whatever i need
W
wydopen
Guest
yea i alreay have another hole taped for the second pisser...i ordered a stock gasket but im worried it wont be big enough for the bore(730cc) any suggestions/reccomendations??
upon further inspection i relized that exhaust was only coming out of the pisser that comes from the pipe not the one that comes from the head...im gonna pressure test tonight and if they are close im gonna call it good..
