- Revelstoke,B.C.
Hey guys, after doing a search and gathering tons of info...did i mention i love this site.... find myself with only one question in regards to the hand warmer mod.
when running the line up through the pole, do you have to drill a hole from the engine bay to the pole?? ie somewhere around the pole bracket?
can you use one of the "one way vents" ? or drill a hole the size of your tubing and then seal it up.
damn..i lied one more question...in regards to temps..is there an actual temp deg range for optimum engine performance or are you guys "winging it" via feel of water temp/engine behavior.
Should prolly' mention this is for an 04 octane
thanks for your help
