Looking for advice. I've got a strange ignition problem.
Fresh rebuild on Dasa 5mil coversion from SS PV engine this off season.
MSD dual channel TL
Fresh carb rebuild with clean filters, jets, and needles
Ski will start, idle, and rev fine when it's cold. After 3-5 minutes of riding my engine acts as if it's running on one channel of the ignition, or hitting the rev limiter...which I know it's not hitting limit. Rev limit is currently set at 8750. I've double checked all my grounds. Initally grounds were the main ground from starter and two additional ground from each MSD coil (negative/black grommet side of coil) to the head. The engine exhaust note is crisp and snappy initially and then changes to lower tone growl and is slow to respond to throttle input and the exhaust note is sloppy.
- I changed the coil-grounds to the couple cover bosses. The new grounds are in direct contact with the bosses...sandwiched between the coupler cover and the bosses. After this change the ski ran fine again for a few mins and then same issue. *** Should I change these again to case bolts or bundle them with the starter ground?
- I just verified fat, blue sparks from each plug (when cold). Have not done this when it's symptomatic.
Last season I had one of my channels go bad and I just moved to the spare channel and isolated the connects from the bad channel with silicone. I have two brand new MSD coils to replace the originals, but I'm getting good spark on both channels.
whatchathink?
MSD dual channel TL
whatchathink?
