FX-1 Fx1 Trivia Question
Flash-FX
No Square..No Round..FX-1
I think so. With the stock pump, when landing an airiel, I was on WOT. I would say that the motor is not working as hard now.
How bout a mag pump in an FX1?
The MAG pump 1" setback w/13-18 swirl = Drag slicks...total traction. Playing in the foam is fun. Unlike before....avoiding that stuff.
just joe
NorCal
My Mag is an anchor... I ride flatwater, my SJ came with it (140mm 12 vein) inc. a Sato nozzle. The only difference I can tell from my 144mm stock pump and the mag, on my SJ, is the weight of the mag.
Have my 144mm FX1 still under construction, and I am sure it will be a huge difference. Though I ride freestyle mostly, when running the buoys with the FX1 and it's 122mm pump, I'd cavitate accelerating through the turns or even when nailing the throttle at a set-up wake. Even bigger motor for next year, so 144mm pump was mandatory.
DsmRacing
Wannabe Freerider
Tampa
We really should start a new thread and compile all the FX-1 pump upgrades in one thread. I've read a few different ways of getting this pump to work. From custom bottom's made, kawi 140mm pump, adapters, or what I hopefully plan to do, which is to enlarge the intake as much as possible, and then reweld the tabs where I need them.
How have you guys installed the larger pumps?:poke:
K
ko2
Guest
Would some of you guy's post a little info on how you did your FX1 144mm pump mod ??? Can I just cut the mount's off a sj or WB1 pump & weld them ??? Can I use my stock FX1 drive shaft ??? Which impeller should be used on an FX1 with mod's ( fp,msd ) ??? Thanx !!!
