- Jacksonville Beach, FL
90Sn with 701 61x/61x, won't turn over when cranking. If you add fuel to carb it will run okay (not great, but runs good, idles bad). But then as soon as it stops it will not start again, gotta add fuel to the carb. The primer has been taken out of the circuit. Ran great just 4-5 weeks ago, but I snapped the pole. Replaced the pole, and it sat for a little (thought I had all the fuel ran out of it though) and have not gotten it to run right since. May have crimped the throttle cable a little. When you start it will idle really high and even a little throttle will ramp it way up. Also sounds like maybe only one cylinder firing? 150 psi comp on both
Did have an issue that it wouldn't stop when lanyard pulled, had to turn fuel selector to off. Have not replicated that though.
Replaced inline fuel filter on one side, had some garbage built up in it, but not in the actual filter, it was in the bottom of the filter where the fuel sits. See attached photo. Can't get it to move around in the filter.
So when I go to crank, doesn't seem like a lot of fuel moving through, but it is running through the return line, so that should be good. Spark is good.
Could it be fuel selector switch? Starving enough fuel so it won't crank? I pulled carb apart, was a little grimy, but not bad and the conical filter was almost completely clean. Its all cleaned and back together, no improvement.
I know I just threw a handful of items out that don't seem to have a lot in common. Not really sure what my next issue to check is. Thanks guys!
