CarFanatic
Fiberglassing Newb
- Cincinnati, OH
does that look ok??? do I need another layer??
I would do one more layer around the holds and over the foam holes and call it good. What oz cloth did you use?
Mark44
I used 12 oz cloth.
I"ll do one more layer tonight.
there is two layers on the bottom of the hold, I over lapped it with that huge sheet I layed. Should I add another sheet on the tray?
When I go to sand this I just lightly sand it smooth?
thanks! I just hope they stay together for along time
You think I should do another layer in the tray?
you can get low temp curing epoxy for colder temps.
I tried using regular epoxy outside one winter, it cured VERY slow, I had heat guns, lamps, all sorts of junk and it basically never hardened up.
"low temp" for epoxy means like 50's not 20's...
The dap contact cement for the turf also wants to be real warm
(I think they say keep at 70+ for 24 hrs ..)
..ant I'll say from experience if epoxy sets part way and doesn't harden you have a real
gooey mess to clean up and start over.
