So, in theory, if you created a vacuum in the tray it would float better?
Yes.
The weight of that tray volume is calculated as volume*mass density.
Obviously, a mass density of zero (vacuum) will result in the least weight. :439:
I have a helium tank here at work. Maybe your on to something. I could fill up some atv tubes with helium and put them back there. You're right though. I might end up doing forward flips!
Watch.....someone will go and try this now![]()
I'm almost tempted to try it, I'm just worried about the loss of strength. I'm a noob to flips and rolls, and I will be dropping it on it's side a bit. Would heavy reinforcing be good enough?
It's good enough for the front half, isn't it?. :Banane19:
I'm thinking about just putting foam under the tray, but not in the sides. I'll reinforce the sides, but I'm afraid I'll need the foam to keep from cracking the bottom tray from standing/landing on it. Any opinions on that?
