sounds good to mehose going from the head to the pipe.
use only the backflush, the standard flush sucks and restricts water flow. i ride surf 100% and backflush only.i have already bought a standard flush kit i plane to use both the backflush kit and the standard flush kit. because i ride in salt water all the time i want the most flushing possible.
put it in between the through hull tube (where the water comes in from the pump) and the exhaust manifold
ok forgive my ignorance but how do you keep them in the "pisser" while the engine is running
I think what he is asking is .... how do you back flush thru the pissers with the motor running . I assume the question is due to fact that you should not back flush using the "conventional " method without the motor running .
