flush kit install????/
ok so i have been looking for instructions on how to install a flush kit. i know its very simple but which line do you have to cut? i believe i am supposed to cut the hose on the #2 cylinder going from the head to the pipe.i just need some confirmation please.
i have already bought a standard flush kit i plane to use both the backflush kit and the standard flush kit. because i ride in salt water all the time i want the most flushing possible.
stanton
High on jetskis.
atascadero,ca
use only the backflush, the standard flush sucks and restricts water flow. i ride surf 100% and backflush only.
QuickMick
API 1104 AWS CWI
ok forgive my ignorance but how do you keep them in the "pisser" while the engine is running
Its a snug fit and will stay in both pissers while your engine is running.
No need to unscrew that cap to flush. They also double as spray down nozzles to clean your ski and in your pump area.
I think what he is asking is .... how do you back flush thru the pissers with the motor running . I assume the question is due to fact that you should not back flush using the "conventional " method without the motor running .
yes exactly i went ahead and installed the conventional one i will purchase the other style as well.
