Ericfox
Do it twice?That's DooDoo
- Akron area --> OHIO!
1st... has anyone else noticed that no matter what you set your pipe screws at--> there is not much difference in performance at all? I tried about 6 widely different combinations with almost no noticable difference....
2nd--> does adjusting your high speed adjustment screw really help freestyle riding? I have mine pretty close I'm sure (1.5 turns out with all the regular mods except porting)....I dont know if its worth fine tuning it since I should not hold my ski very long at WOT to test it... and I just dont know how beneficial the high speed adjustment is to freeride
3rd--> to all you guys that use the idle to kill your ski --> how long does it run before it dies when it idles? My ski idles a little bit higher rpm sometimes than it does at others... I assume this is pretty normal because of air temp, water temp, barometer, fuel quality, etc... does anyones ski ever NOT stop idling when you fall off? Does this happen pretty often? Does it just circle or what? I am just a little worried about setting my ski to die from idle- but I do want to do it so I can try some different tricks eventually...
