just got off the phone with us composites from ordering everthing i need to get this done should be here first of next week they said. so while i am home i will work on getting the foam cut and put in the tray.
Well I got a little fiberglass work done today filled in the rear bond line in and then layed a layer 1708 on one side will do the other side tomorrow. Also filled in the square where the scupper went on the same side.
5200...You can mix epoxy resin/cabosil/fine saw dust and make a pretty good glue but it is not as flexible and can crack...5200 will give a little and wont crack.
our local walmart and about every hardware store carries 5200 here, but as you know i live right next to lake texoma. If you have to order it Mcmaster carries it.
