onesojourner
I use a thumb throttle.
- springfield, mo
This is a beta version for the tech faq so add anything you can think of and I will update it. This is assuming you have a good running 650 in the ski.
Parts you need.
1: 701 head (61x or 62t*)
2: 701 cylinder (61x or 62t*)
3: 701 cases (61x or 62t) actually all you need is the top case half, though mixing cases is not recommended.
4: 701 pistons
5: 701 piston rings
6: 701 gasket set.
Tips for doing the swap:
*intake manifold must match cases, you can use the 6m6 44 SBN on a 61x manifold.
*upgrading the CDI from the 6m6 unit to either 61x or 62t is recommended, ups revs from 6700? to 7150?
*if your using 62t cases and stock carbs (or front pull), i recommend swapping to a rn throttle cable, but it is not necessary.
Parts you need.
4: 701 pistons
5: 701 piston rings
6: 701 gasket set.
