Just had the idea while getting all of the fluids in my Jeep Cherokee drained and then flushed and filled.
Could a couple of plugs be put in to a thick area in the crank cases so that a 2 stoke could be flushed and or oil bathed for whatever reason? (Say it sank in saltwater in Daytona07 and then it would not start and then it got driven back to Ohio and put away in the middle of a blizzard for example:clown
I could not run it but I could have filled it with 2 stoke oil (or whatever would be best) and sucked it out and repeated. NO TEAR DOWN:no:
Like 1 up high by flywheel cover and one down low in back and just seal it really good with a dab of 5200 (an air leak would be really bad!)and some pipe cap? I have capped cases before for carb changes.
