jetmaniac what have u found so far...any progress...don't leave us hanging. was the ski really running great one day and that like crap the next...if u mentioned that i missed it. if that the case check your fuel pathas suggested by the others, if not...clean/rebuild your carbs
lets make sure we're all clear about what i mean when i suggest a rebuild or to replace internals. i would love to have a set of carbs that never need rebuilding but lets face it the odds are against that happening, my skis can sometimes sit unused for months.
however, lets also keep in mind the fact that the carb is designed with parts that wear, and as they wear the carbs fall out of tune and eventually fail. other parts do not wear and do not need to be replaced when "rebuilding" the carbs, a good cleaning is enough.
parts like, diaphram (both rubber and plastic), one way valves (plastic discs), rubber cone on n/s, plastic oval stip on metering plate,etc all wear at different rates (faster when ski sits fo extended periods). but they all wear and eventually must be replaced. the small plastic discs that function as check valves in the pump are usual suspects of carb malfunction, and the small oval on the metering plate is often ovelooked (should sit flat on plate and let fuel in not out).
the jets, springs, spring arm, small filter etc. are not wear parts and in my experience rarely need changing. sometimes if small filter is dirty its easier to just replace it then try and clean it without damage.
so when a carb rebuild is suggested, what's really meant is to replace the parts that are worn out or wearing and clean the ones that aren't.
square joel and penguin i'm sure alot of us have felt your pain with those check valves. i say leave em in if they seat well and aren't bent, ripped, cracked, warped or shriveled (spelling??) and the little rubber holders, i always try to pull them through instead of pushing (hard to explain exactly how)...ive punctured too many to try the ball end allen again, even the Mikuni tool sucks!!
i'm gonna stop now...i think this is my longest post ever
