Ok so we tested the charge coil and pulser coil and they were both in range and almost exact with a known good stator. On the ignition coil, it has new wires and the MSD boots. From what I read, the MSD boots do not have resistors. What would happen if you ran non resistor plugs? The ski currently had B8HS installed. Also the CDI unit is a WSM unit which I know nothing about. Another big culprit is the wiring mess. Previous owner changed out every connector and they seem sort of junky. Pulling some apart, they broke so that can't be helping either.
