Electrical Help Please
JetManiac
Stoked
orlando
There is lots of good advice in this thread.
I think you should find out what the issue is, or more likely issues are, “before throwing the baby out with the bathwater” and switching to a 760 setup. Many guys are running a 62t setup sucessfully. It is easy to swap an oem 62t flywheel to see if that is the issue. Leave it in there while you test for other things.
As others have said above, secure and stable power and ground cables and connections are needed for any electrical system to function and be reliable. Your pics show many wiring issues which are common, we see them all the time in skis.
All cables need to be marine grade, which means no raw copper wire. Copper is highly conductive, but also highly corrosive. Marine grade wire is tinned to slow down this corrosion.
The crimps in most or all of these pics are upside down. They look weak and possibly intermitently tight if at all.
Most crimp on terminals are made from flat metal which is rolled, and the joint is on top. There are different types of crimpers for insulated and for uninsulated terminals, either can make a good crimp.
When you crimp a terminal, make sure the rounded part of your crimp tool matches up with the line where the 2 ends of the metal meet. Then when you crimp they stay tight together and the tool’s crimp pin pushes in from the bottom against solid metal. You get a nice tight crimp this way.
More upside down weak crimps on wires. Extra wire splices, non waterproof butt splices and terminals all over the place. Your system is as reliable as the weakest connection.
New power, starter, and ground cables, new ebox gasket, new fuse holder assembly should be installed before you do anymore testing.
Those type of crimps pictured on the cables suck period , I crimp connections all the time, for terminals I have the correct crimping tool, for cables I bought a hydraulic crimper , pretty much all the wiring I can see in his pics is questionable at best , maybe I might try to diagnose a ski with wiring like that but I would never try to actually run it in the water like that , you are just asking for it .
To the guy that thought that was a good ground location , don't quit your day job , you won't make it repairing Jet skis for a living.
Roseand
The Weaponizer
Wisconsin
Sticky this.
We are spoiled to have you help the sport!
JetManiac
Stoked
orlando
Agree. For battery terminals, a large crimp tool or hydraulic tool is best for sure. For small terminals, a standard hand crimper is fine.
For those who think that a bad Battery Ground location will not damage electrical components or cause erratic performance, go ahead, do the experiment. Bolt your Negative Battery cable to your Flywheel Cover and expose your high dollar components to this abuse. Prove it on your own Ski. Are you 100% sure the Battery Ground location is not critical?
FAFO :p
Big boy set lol
sick set. literally just looking getting something like that. and i guess since where all hear talking about how we would do things better, my question to everyone is why i dont see alot more deutsch plug connectors on jet skis. i want my wiring to be easy to connect and disconnect thats "water tight". in the Marine industry all i see is deutsch plugs.
I am used to working on Seadoos with Weatherpak connectors but yeah same deal
i mean if i can set my freestyle boat up with something like this, id be a happy camper.
DylanS
Gorilla Smasher
Lebanon Pa
Bought a big 100 dollar set off eBay of them and that’s all I use for the total loss setups. Super easy to troubleshoot. Those and those little oem style bullet connectors JM sells!!
