electrical box removal ?
trying to remove my e-box and those 3 philip head bolts that hold it on wont budge. is there any trick to removing them? i tried pretty hard to break them loose , but im afraid if i try any harder i might strip them. any advice?
by the way , its on an fx-1 ( not sure if its any different than a sj)
gj_fx1
X-H2
Try a screwdriver bit with a ratchet/extension, that way you can torque it and hold force at the same time. Key is to have the right screwdriver tip, big fat one with a blunt end I think.
I Keep meaning to replace those buggers with socket heads..
njfl
X-H2
FX-1 electrical boxes are mounted differently than SJ. They use those three holes that are seen in some of the earlier aluminum halves of the box.
Use a hand impact tool or tap a screwdriver with a hammer as you are turning. It is very probable that the stainless has fused to the aluminum and will be tough to get out.
