Mark44
Katie's Boss
- 100% one place
When does this come into play? Should I drill and tap the case while the motor is apart?
701 Magoo port
duel 44's SBN
B pipe limited
Mark44
701 Magoo port
duel 44's SBN
B pipe limited
Mark44
Mark44 said:When does this come into play? Should I drill and tap the case while the motor is apart?
701 Magoo port
duel 44's SBN
B pipe limited
Mark44
Mark44 said:Cool thats Matt and Slut glad I asked before I finished the case.
Slut,
Hows that motor hit? Did you go with Pro X? Paul is doing my cylinder right now.
Matt_E said:GAH! I just remembered...I was supposed to get back with you on an intake manifold.
AH! Sorrry, I forgot about this.:17:
701 Magoo port
duel 44's SBN
B pipe limited
Mark44
Mark44 said:I talked to Paul about that same thing, he said it would be ok but to really open it up I needed 44,s. Then I lucked out on a set on e bay for 150 bucks so I dont need to use my spare set of 38,s. Do you need a set of 38,s cheep?
And Matt E may have an intake.
Mark44
I'm interested in dual 38's for cheap. let me know.Mark44 said:I dont need to use my spare set of 38,s. Do you need a set of 38,s cheep?
