Dual Cooling and B-Pipe Fittings
Does it matter wether I use strait or 90 degree elbow fittings on the cylinder head/b-pipe? I’m asking because the b-pipe came with two 90 degree fittings and my modified cylinder head came with a strait fitting, I’d like to swap them to make a more direct line/ less bends. Also, is this proper for dual cooling with a b-pipe and flow control? 340D7AF4-A847-4A30-B46F-12A0821A389C.jpegimage.jpg
Stockton
90’s on the manifold too....
I’ve seen 90’s used on the head pipe as well.. I don’t... though
Yeah that Y or T or whatever it is at the flow control seems unclear.
If it’s a T, straight leg of T overboard and T off it to Fc
I just found that picture on here, but I will be using a T going strait to the FCV. the leg off will go to the pisser so hopefully the main pressure will be against the flow control
