- Toronto ontario
Hey there i have what i believe is a coffman dry pipe.. bolted up to a 61x with some goodies, stuffed into a pump swapped wavejammer, running dual cooling... my question is water routing.. drew up a little diagram and was wondering what the “?” Fitting line would run.. ive attached a photo of the diagram, pipe, and head im using (westcoast 160psi head with only 1 fitting)
Thanks
Thanks
