per the waterhawk
make sure you run the EXACT oil mixture or you will blow you engine. if you are running 50:1 do not mix it any different or you will have to rejet or blow your engine. it will not foul you plugs, like thought before. IT WILL DESTROY YOUR ENGINE, PERIOD. all you people that have changed fouled plugs due to too much oil need to not change your plugs any more. you must rebuild your engine. even though changing the plugs seemed like it worked, it is just a figment of your imagination.
you have been worned by the waterhawk.
LOL...I accidentally put some injector cleaner in my truck too...should I rebuild it too?:bad3:
