Super Jet Disabling lanyard kill switch?
JT_Freeride
John Tetenes @Jtetenes
Long Island
Hey I was wondering if there was a way to disable the lanyard kill switch. I'm asking because its gunked up and won't work and I want to ride while I wait for a new one. Before anyone asks why would I want to get rid of the kill switch?
I don't use a stop anyway I've been through 3 s/s switches this year and everyone the stop breaks and causes it to engage so I just disconnected it and lowered the idle to where the ski would just die after about 4 secs. Perfect for being in the air
Disconnect the white and black connectors at your ebpx. That is the stop circuit. Make sir and turn down the idle if it's set up.
Sent from my DROID RAZR using Tapatalk 2
Poizen
Mical
South Africa
where do they leak i opened mine today and every switch is sealed mine is a 09 but i doubt much has changed since they started making them
like they say it should last years
Big Kahuna
Administrator
Tuscaloosa, AL
There is a metal disc on the start stop portions of the switch that can get some buildup that will cause the buttons to stop working, clean them off and usually your good to go......... As far as the Lanyard part, I have never had or seen that part of a switch go bad. Just bypass that part of the switch, all it does is ground out the circuit just like the stop switch does.........
Joker
...chaos? Its Fair!
Just had to clean the kill switch part last week
tor*p*do
Squarenose FTW
NW NC
you can zip tie it!
not recommended, but you can get a new set of switches for $60 plus shipping
so why risk your ski/life/liability?
JT_Freeride
Long Island
Well turns out after I cleaned the switch completely and had it working perfectly my UMI decided to chew up my wires because I forgot to zip tie it in a safe place FML
seattle
dont disable it unless you want the chance of your ski looking like my profile pic. all my ski will have lanyards from now on..
Joker
...chaos? Its Fair!
If you disable the kill switch all you have to do is turn the idle down so it shuts off when you let off if the throttle
