difference between the thrust trims?
With out the coupler mod the X metal trim is gash. Put the coupler on and its night and day difference, was amazed how good tbh. Makes big spins effortless, and has more than enough trim. I've got mine backed off a bit now.
Personally id only run the xmetal now as its been flawless and works perfect.
How hard is the coupler mod to do?
Sent from my XT1585 using Tapatalk
Uk
Its Easy ill find the post on here.
I did find some silicone hose that was slightly thinner than the Stock b pipe coupler and works even better as less resistance. All I do it put a little grease on it before I ride and steering is super smooth.
