- USA
Went out for a ride, corner of my eye I saw something in the water...whatever. 20 seconds later the ski loses power and sounds like i just blew the motor or lost the rings. get towed in. ski looks ok on the inside , starts ok but with a little throttle starts to loose power again. parked it for the day. at the house checked the compresion...good. shaft is spinnig freely, so is impeller. But pass the impeller found a 2 inch wood stick about 3/4 inches thick, chopped on one side, just laying at the bottom of the pump. Did I run over piece of a bigger stick that just got chopped up along the way? should i double check anything else? Has this happen to anyone?
