- central florida
Yes Mr Sano, I would like to share the following: Consider installing the impeller housing first with the two 10mm capscrews, then you have more wiggle room to install the pump. After fastening the rear- the reduction nozzle- you might remove the two front screws, apply loctite and reinstall.Would someone tell me why the hell it is such a pain in the azz to install a pump and drive shaft into a midshaft bearing!!!
Put them in for years.Last couple of ones it went fine.Ten,fifteen minutes the pump was in there.Today l spent at least an hour trying to get the shaft in the hole.Had to walk away cause l was getting pissed.
So if anyone has got something special they want to share,l would appreciate it!
