Super Jet Dam Pump Install!!!
Would someone tell me why the hell it is such a pain in the azz to install a pump and drive shaft into a midshaft bearing!!!
Put them in for years.Last couple of ones it went fine.Ten,fifteen minutes the pump was in there.Today l spent at least an hour trying to get the shaft in the hole.Had to walk away cause l was getting pissed.
So if anyone has got something special they want to share,l would appreciate it!
Yes Mr Sano, I would like to share the following: Consider installing the impeller housing first with the two 10mm capscrews, then you have more wiggle room to install the pump. After fastening the rear- the reduction nozzle- you might remove the two front screws, apply loctite and reinstall.
Sanoman
AbouttoKrash
NE Tenn
l totally agree with you.The housing was never removed when l pulled the old pump.
Looking forward to a good drink on the beach when l see you Fred!
Sanoman
AbouttoKrash
NE Tenn
After all the other problems with fitment,l find that the oem pump shoe is broke! So let's order one of them.l'm glad l found it before it became a problem,but why right before daytona.
