- Ocala, FL
Im finally about to start rebuilding my 61x but after test fitting the crank it doesnt seem to seat right. It took a few tries but i finally got all the pins lined up with the bearings and dropped the crank into place but it rocks a little bit like the center bearing is a little too big. Will this be an issue or will it be ok once i bolt the cases together? It doesnt rock a whole lot but you can tell it has movement to it.
