- union lake, michigan
on a superjet-single line cooling, how do the cooling lines go? when i took it apart 1 line went from the head to the underside of the factory b pipe and then line 2 went from the top of the pipe to the outlet, and the MAUNFACTURER says line 1 goes from head to the top of the pipe and then from the botm of the piupe to the outlet-althought they did say some people do hook it up where the water does flows from the head to the bottom of the pipe-has anyone routed it from the head to the top? whats the dif ? does way works better?-it seemed to work fine last year when water went from the head to the btm of the pipe-SUGGESTION????
