compression 200psi
chunky
97 Superjet
N.Ireland
thats a good idea with the gasket, find the compression wanted using gasket thickness and then machine the domes instead of taking two or three attempts at the domes themselves.
you learn something new every day.
chunky
97 Superjet
N.Ireland
took 5 thou of the squish and the compression came down about 8 psi so the ski is still running around 192ish psi.
advent should be here soon so think i will just take it easy up top until it gets here then get it set to retard a bit up top.
