common mods on sxr
CT
Just picked up a 07 sxr today. Dead mint all stock. What are the must have mods? It has plenty of power for me. I'm not looking to increase that. Today was my first day on it. I noticed it was real rocky. Nothing like I was use to. I'm sure it is just me and I need to get use to it. But is there any stability issues. Will a ride plate fix it?
I haven't had any stability issues with any of mine. By far the most stable ski I've rode even stock. Maybe you just need some time to get used to it.
OCD Solutions
Rentz, GA
I was gonna say, if you think the SXR is rocky, your last ski must have been a pontoon boat, lol.
All I ever did to mine was a TBM rideplate, rear sponsons, straight bars, ODI grips and a hood block-off plate.
CT
Thats what I thought, its just me. The ski sticks to the water and will turn as hard and as fast as long as you have the power to hold on. I'm coming off a 650 sx. Whole different monster. What I meant by rocky is that it takes very minimal movement for this ski to want to turn left or right. At mid to high speeds it feels like it will come off plane and just turn left or right. Little scary at first. But again had one day to ride it and it was the first ride of the season as well. I'm a little out of shape also. Ha.
Vumad
Super Hero, with a cape!
St. Pete, FL
Do nothing to it. Ride it as is. Mod for your specific needs as you develop your own riding style. Lots of people will tell ypu to throw money at it. Ignore them. its nice not to have a wrench i your hand.
djkorn1
kidkornfilms
Cleveland Ohio
I would put 4 or 0 degree handlebars on it to move you forward. Besides that, it all depends on what kind of riding you want to do. jump? carve? top end? bottom end? freestyle?
Give it some time. The SXR is the MOST stable standup out there. Get some hours on it....and you'll be fine.
I think you are talking about chine walk. While cruising, the boat tips left to right, correct? Out of my 3 SXR's, only one does not do this. It only occurs at mid throttle? If you just cruise, and don't hammer down, they have a tendency to "wiggle", like rocking back and forth. It seems like a longer ride plate enhances this.
Is this what you mean? Let me know, I've learned a lot about these hulls, and all three are 07's. I just love the red and white.
Scorn800
Ride for life
North NJ
Listen to him!
Stock SXR are so much fun. I like just bars,grips, spring block, and TBM intake grate. Don't touch the motor!
CT
Yes, this is what I'm talking no about. So the longer the ride plate the worse it gets? I also noticed it starts to propose at high speeds.
CT
Listen to him!
Ya, I'm not touching the motor. I know super jets have a list of must have mods. Wasn't sure if sxr had similar must have mods for handling.
Vumad
St. Pete, FL
Porpoising and chine walk can be caused by the rider, riding condition, the setup My sxr doesn't really do either, but I've ridden plenty of skis that do.
Ithe new to you so you need to spend you time practicing and seeing if you can eleminate your complaints over time.
Front or rear sponsons could help, and so could an extended ride plate, but I felt that the sxr I rode with sponsons porposed more, and I ride d-cut plate recreationally and have a longer one for other times. Imbalances in the ski such as an improper battery size can cause this too.
There's no substitute for saddle time.
bird
walking on water
Get some marine grade silicone.
1. Fill the Pump Shoe voids, increases the hookup in all conditions!!
2. Seal tray bumpers on the outside, they will peel up over time laying down in the turns!
Ride the stock plate and intake for a while, get used to them then switch. I went with a longer TBM first and hated it, now I have a D-Cut Kenny Lip Ripper. I'm still rocking a stock intake.
I can't stand 4 degree bars, they gotta be Zero.
Your handelpole WILL break!!! Start saving $50 bucks a month now. Ride Time > Wrench Time. Practice!
bird
walking on water
I only rode lakes and rivers on my "new" 2011 SXR starting in mid March, it was cracking early July. I ride hard, you will too some day if you keep practicing!
It doesn't just snap off unless you stick some wave or crash into something! It will be a stress crack on the side near the chin pad or down near the pole mount.
You could reinforce it now...but just keep practicing!
Vumad
St. Pete, FL
Just ride the stock pole until you are doing tricks that can break It. I ride with lots of people on stock poles that race hard and regularly without problems. I agee that if you start doing nose stabs, reentries, and other tricks that put leverage on the pole then it should be a rush, but its probably not for new riding. I got a lot of the same about shortening the pole on my superjet, but i rode it for a year stock before i did, and tried other skis to decide the length first.
Ride it like you stole it this summer, just be careful with excessive lateral forces or hyperextending the pole, and you will likely be fine. By winter, youll know more of where you want your money and wont mind having the pole off if you want to beef it up. It cant be shortened, so who knows, by the time you need it beefier, youll want a whole new pole (xmetal, rrp, superjet, etc).
djkorn1
kidkornfilms
Cleveland Ohio
Just ride it. If it breaks, get an aluminum one. I'd go with XMetal, lighter and cheaper than RRP and look better on SXRs. I think you've got a year or 2 before you will break it on flat water depending on how much jumping you do and slamming it on the hood.
As far as handling....SXRs handle better than any other boat (less porpoising, very stable). Just get one foot forward in the tray and put the bars on your waist when you are riding and it should stick to the water.
