- New York Crew
Well Ed Brazina suggested checking the timing on my stock flywheel with the MSD enhancer. I wish I had done the stock ignition also, but I want to get this done and back together soon, so I'm keeping the test work to a minimum. I am changing to a TBM flywheel as soon as I'm done checking the timing with the stocker. #Zero gave me the idea for these stickers, and after about 15 min on autocad, here they are. Redrocket was nice enough to print them up for me. The stickers make it nice for checking the timing so you don't have to check TDC on both cyls, cause they are marked at 0 deg twice, 180 deg apart
1) Made up an aluminum bracket with a notch for the deg indicator line. I just drilled some holes in the plate where the coupler cover bolts go.
2) Take motor to TDC with a dial indicator.
3) Scribe a line where TDC is on the coupler.
4) Attach sticker to scribed mark
5) Fire up the timing light!
Sat morning hopefully I get all the numbers
