This happen to us before but we caught it, the plate was loose and throttle / ski wasn't performing , sluggish ....
Did u notice anything while riding or did it come loose so fast and drop ?
This is a build I'm doing for Hassan. He's moved back to Saudi Arabia, but he's back in town for a few weeks. We were going to squeeze in as much water testing as possible, and then this ski, as well as an Edge, would get crated up and shipped. I just finished this build a few months ago. Since the clock was ticking...I decided to get some tray time on the ski before he returned to San Diego. I took the ski out 4 different times and it ran like a turd. Everytime. Totally unrideable. It had moments of brilliance, but each time I turned the steering hard left, or hard right it fell flat. I was trying every trick I knew to get it to run right and it wouldn't cooperate. The mindf*ck was that it is a recipe that I've used on my personal setups with the exception that this build was using a Zeel ignition...whereas in the past we've always run MSD. I tried different curves and even swapped out flywheels. Nothing worked.
Then, with time running out...I decided to pull this motor and throw one of my backup Dasa motors in, so that I could get this boat running with a baseline setup, that I knew was solid. I pulled his motor and threw it on the bench. After puling the head, I saw the telltale signs of something letting go. I immediately assumed that it was the crank going tits up. I didn't break the motor down any further, but I felt somewhat relieved to finally see what was going on. Or, so I thought.
Meanwhile, I throw this same set of carbs on my Dasa motor. Note: I still haven't noticed the missing throttle plate screw. And we were slated to test that following weekend. On a whim..and with a few extra hours to kill, I decided to break the rest of his motor down and get the crank sent out for a rebuild. When I split the cases...to my horror, I discovered that it wasn't the crank letting go..but in reality it was a screw that had been dancing around!! I assumed that I f*cked up and had dropped something in the motor. I was my fault. I was going to have to cover this expensive mistake!
However, it was tiny screw. It wasn't a screw I recognized. It's not any screw that I would be messing with on a motor rebuild or ski build. Well, maybe I somehow dropped it in there while running the ski with the flame arrestors off? Where the F*ck did this screw come from?
And, then it hit me! The light bulb when off... I peered down the carbs of my motor which was now sitting in the ski, ready to ride, and saw the smoking gun.
F*CK!!!
![IMG_7760[2].JPG IMG_7760[2].JPG](https://www.x-h2o.com/data/attachments/343/343009-22abb1915f88bddcddb6a82af554aeac.jpg)
