Working on our 1100 SXR. About every third time you hit the start button you just get a click and it getting worse. Checked the easy stuff first, start stop switch with an ohm meter and works perfect. It's clean inside and connector checks out fine. Both the battery, cables and all connections check out good. When it does crank, it spins the engine over very easily and fast. With a volt meter between the starter terminal and a ground, when you hit the start button, if you get a click, you have no voltage. So this leads me to the starter solenoid is bad.
The ebox is beside the fuel tank, so there's no way to get it out or apart without moving the tank. To move the tank on our ski you have to pull the engine.
Before I pull it, did I miss anything?
