Chamfer
ski4
gonzo
cleveland
Damn, after putting the whole motor together , i figured i would find out if the guy that charged me $60 a hole to do my boring chamfered it. I did not even really give it a 2nd thought for what i was paying. i only recall thinking at one point " damn these are sharp" but was too pissed about my terrible decking job and non rotating crank
turns out he did not arghhhhhhhhhhhhhhhhhhhhh
any how, i have been told, and am reading to use a round file or dremel. anything wrong with a flat file? just curious why round is preferred
and i only have flat files laying around
I did mine with a dremel - very very carefully, of course. A flat file would work just fine.
SuperJETT
none
Round file or Dremel. I always use a Dremel, just be careful. I use a 3/8" cylinder stone I believe.
ski4
gonzo
cleveland
matt if it is the shop by dj's
yes you should do yours too i bet.
good call about the exhaust port makes sense, i best go get a round file then
ergh
As long as the flat file is thin enough, it should still work.
It's been my experience with a couple of shops that they do not chamfer ports by default.
Jr.
Standing Tall
Staff member
Hot-Lanta
Thats true, most shops don't automaticly chamfer the ports.
I tend to do it for my customers as a curtisy because I know the intended use.
If you want to do it yourself easily, get a small round file & finish with some emory paper
