Trying to tune a new Full Spec 49. I have the high speed nearly closed (1/4 turn from closed) and have worked the low speed from 3/4 turn to 2 1/2 and cannot get the bottom end to clean up. I can get the middle and top to be nice and crisp when I set the low speed at 1 1/2 and top at 1 1/4, but the bottom is real rough and sputtery no matter where I set the low speed adjustment. I almost have to roll the throttle open easily until mid lever throw and then get on it for maximum performance. Any ideas? Engine is ported/epoxied/trued compression is 185 with fresh gaskets, fuel line and filters.
