- deland fl
i have a waveventure with a dual carb 701 in it. had to clean the carbs out recently due to sucking some nasty stuff off the bottom of the fuel tank. i thought they cleaned up pretty good. wont run on its own unless i hold choke closed. just by chance while messing with it on the beach, it was leaning on its side (carb side down) and it would stay running and accelerate like normal. while running, if i tipped back to sitting flat it would shut off. do those symptoms provide any clues as to what is wrong in the carb? (tank is 2/3 full) nothing appears to have gone through fuel seperator since i cleaned carbs
thanks
edit: different engine than the last "help me thread"
thanks
