showmepro1200
ISJWTA Member #007
- Jefferson City, Missouri
Freshwater, Lake of the Ozarks. (sort of fresh I guess, haha)
We replaced the head gasket (o-rings) with Protec rings last year. I have another set, I guess I can do it again (sigh). Since then we've replaced the coil/wires/plug ends (all new), new 'lighting' coil (green wires btw), swapped stock CDI in for the enhancer and now back, replaced crank seals front and back. Stator is tight and set right on the arrow mark, cause I did it myself
The water getting into the carbs bothers me, I think we are getting a lot of spray/splash into them from the hull (no leaks in hoses, Ive run it hood off on the lift). Yes the intermediate shaft cover is on there too. I want to retro-fit a stock flame arrestor back on the carbs to knock out that possibility.
One other item - when putting it all back together electrical-wise, I got dielectric grease to squirt into all the connectors in the e-box, and also put some into the black and white two-wire connectors. After doing this, I found that the white connector wouldn't stay locked together, seems the tab that locks is weak and letting the connector slip back out. I bent the tab a bit and now it holds but if you push/;ull it you can get it to pop apart. I went ahead and pushed it together and electrical taped the connection up. Just wondering if that could be breaking connection once in a while and causing trouble (but it 'fixes' itself so I don't think so).
Only other thing I can do is pull the carbs and check the inside filters out - but like Jake said these are brand-new Blackjacks from Art - I hate to pull apart a clean and proper-running carb and find nothing.
