bubbles in epoxy/filler
The Penguin
triple secret probation
I'm trying to get my hull finished and to a painter. As I get the tubbies sanded down, I see I have many small bubbles in the fairing filler.
How do I fix this? I'm thinking either another skim coat of fairing filler and more sanding - or to ask the painter to hit it with some high-build primer to fill them in and sand.
thoughts?
a thin skim coat will do the job. You're painter will probably give it a once over anyway with thin body filler unless he really is just going to shoot it with a gun.
Mark44
Katie's Boss
100% one place
In the future
A good way to keep the bubbles out of your epoxy is to first mix the epoxy and hardener with a round stir stick not a Popsicle stick or pint stirrer then to take it a step further is to pull a vacuum on the mixed epoxy container for a few minutes.
Mark44
The 407 is a low density filler ,I personally never use it ,I like the 410 microlight(glass spheres) much better,if you need something a bit stronger than microlight just add in some 406(cabosil) to make it the density you prefer,but the more 406 you add the more difficult it is to sand
The Penguin
I used 404 (High Density Filler) for filling in the larger gaps and 407 for final shaping.
and 404 is a bitch to get sanded down where it was not needed. :biggrin:
Q
QuickMick
Guest
Marine Tex will work to fill in the small bubble holes. Just squeegee it on and sand.
shawn_NJ
Chasing waves.
Daytona Beach
In the future
Mark44
Thanks for the tip, I'm going to try that this weekend.
