VXSXH20
Sionis Industries
- Mid-Atlantic
This is very true. I asked the 2 builders I use and both said similar responses. Good luck to all carry onPorting something does not always give you more.......... Ask your builder...........
Would this thing work in a drill press for me? http://www.ebay.com/itm/SB-5-CYLINDER-CARBIDE-ROTARY-BURR-FILE-CUT-1-4-x-1-2/130394998588?_trksid=p2054897.c100204.m3164&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20140407115239&meid=c57063d62ba644ef94ca70b569a2d74e&pid=100204&prg=20140407115239&rk=10&rkt=30&sd=131253054560
	those are the style i use as opposed to the ones quince suggests. if you dont want it to plug up, use mig dip or regular grease or even wax. warm up the bit, dip it in the grease, grind for a minute and dip it again. they dont plug up on me, ever.Would this thing work in a drill press for me? http://www.ebay.com/itm/SB-5-CYLINDER-CARBIDE-ROTARY-BURR-FILE-CUT-1-4-x-1-2/130394998588?_trksid=p2054897.c100204.m3164&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20140407115239&meid=c57063d62ba644ef94ca70b569a2d74e&pid=100204&prg=20140407115239&rk=10&rkt=30&sd=131253054560
You will seen more gain from tuning the water screws on the headpipe. What impeller and pump are you running?I am going to bring this thread back to life. I have a ported 760 build. I know there are not many speed freaks on the X but there is more activity on the X in general. I have a goal of building a 60mph ski without sending the motor out to anyone. So far i am at 53mph with pretty awful compression (i used a junk cylinder for my first time porting, 140psi with 40cc domes lol).
The pipe is a B pipe with Mod chamber. If all i care about is peak HP and RPM, then porting my mani and headpipe to 50mm should help. I have been looking everywhere for evidence of this. Of course i understand that peak HP/RPM is a combination of every working part in the system.
As a side note, i did get 2mph more from a Mach 2 pipe. But i hate the way it mounts.
I am running a Hooker 10.5/16.5 that i pitched and measured myself using a granite surface plate and a slide height gauge, measuring every half inch at the blade's edge. See example pics. The prop was ordered as an 11/17. Just for fun, notice the original measurements. I am aware that my method is not perfect.You will seen more gain from tuning the water screws on the headpipe. What impeller and pump are you running?
As for tuning the screws, i do agree that is very important. I found something very interesting. I am getting 7250rpm. I installed a drying switch that pulls all water from the exhaust when i flip it. This raises EGT and sends the wave back sooner (also affects scavenging, but i already have top and middle screws closed so i am mostly affecting returning wave). This should allow my RPM to increase, but it doesn't. I get the exact same RPM with the switch flipped. This means the Mod pipe with my current settings (T closed, M closed, B 0.5 turns out) is returning the wave at OR before the optimal time for this RPM range with this prop already (the mod pipe is actually TOO short for my current setup). So, i will try actually turning the bottom screw out very slightly to see what happens. Although i am yet to add a FCV, and i also want to get rid of my dry switch for now. So, adding the FCV and removing the dry switch will increase pressure at the headpipe a little bit, and bring a bit more water in. So i will do that before making screw changes.
FYI, the dry switch works wonders on my other ski with a limited chamber and a totally different motor/carbs. I have that pipe setup for low/mid powerband for freeride. When i flip the switch i get another 3 mph. This is expected based on the setup.
View attachment 447870View attachment 447871
Only 60mph SJ I have ridden was one of aYou should start a new thread documenting what you are doing and progress. Also @MTRHEAD has built 60+ mph superjets. Do a search for his name and read everything you can find.
yea i don't think i'll ever get there. It's just a good sounding number lolOnly 60mph SJ I have ridden was one of a
Tricky's. This had an old DASA with a Type 9 dry pipe....
