blaster mod chamber superjet
cambo au
TRYING TO LEARN
AUSTRALIA
i have been wanting to try this set up for a while mostly for the ease of working on your ski
i would like to know who has run this set up?
how would you compare it to a limited b pipe chamber?
how much did you have to ding the pipe to get it to fit?
any pics?
i just want to find out the pros and cons of this set up
thanks in advance
chris
SUPERTUNE
Race Gas Rules
Clearwater Fl.
They work well on my 5mm stroker-828cc motors. I haven't run them on a lot of other different engines sizes or crazy ported motors. I only use the exhaust manifold bracket for mounting, and don't use the front cover mount and lets me mount the pipe chamber up and out a little and makes the fitting chamber bit easier.
waterfreak has also run them and they make way more power than the SJ mod chambers on a built motor. i think he has one for sale, too.
cookerq62
Life's Been Good
Upper Bucks, PA
ADET has one on a stock 61x and it's great. I had mine on a ported 62t and it was also great. You really need to restrict the water going into the 'stinger', this really gives it a much snappier response. Without the restriction it loads up the waterbox pretty bad. My chamber was dented but I think adet's is undented and it fits no prob. It's easier to install and its stainless, pretty much a no brainer for me.
yamahammer
are you men the police?
San Angelo, TX
mine on my superjet ran ok- it kept coming loose off the headpipe when i would jump big or pancake so i switched back to sj mod chamber and i think it runs better on my setup- 760, 44s, vforce, 170psi, stock ignition- maybe if i had fewer cakers it would still be on there, but what fun is that???
