Bilge bracket question????
aqua
the taco
i bought a bilge bracket from hot products and it looks like it goes on the side of the midshaft over by the stock pump strainer. I want to run the stock strainer at the same time as the bilge and I am not sure whether or not I will be able to use this bracket. I read an old post that said the strainer would attach to the bracket but I am not sure it that is right because the bracket will put the single bilge right where the stock strainer is. Any body know? thanks
Ericfox
Do it twice?That's DooDoo
I ran it before I did dual cooling... you can do it... there should be a little screw on your bilge bracket that you can use to attach the stock bilge bracket to... it is a little tough to do all this since it is so frickin tight to work back in there, but you can do it...
oxnard111
Creative RE Purchasing
don't know if this helps, but I just sold this single rule bilge bracket, and it had the stock bilge/strainer attatched to it. Don't know if it came that way or if the previous owner tap the hole for the screw.
Ericfox
those brackets should have a little tapped hole with a small screw that come with them... the one I ordered from Parker did, and I assume they are mostly all made by the same company...
aqua
the taco
ok....im stupid. yes mine does have that screw and now that I see a pic I realize it will work fine. i didnt know what that screw was for. thank guys
