Mark44
Katie's Boss
- 100% one place
Need help on big throw can someone give me some tips. Just not working out for me and I have no teachers.:banghead:
Mark44
Mark44
Some excellent advise here...
As mentioned above use your trim (makes a huge difference) and blip as described to rock into the trough steering slightly right , drop into the trough and gun it full bore and crank the bars full left and throw the handle pole to the right - this gets a crazy amount of rotation! - kick with your right leg as you take off as well. The most common mistake is to kick before the back of the ski has completely left the water - doing this takes 80% of the rotation out of the trick.
The 'S' flick on take off adds most of the height.. a D cut in your plate + trim system like CATS will help too..
Here's some I was doing last year + Ant Burgess doing a big daddy throw (like a backflip with you next to the ski!)..
Sounds like great info! thanks
One thing I would say is they smash the ******** out of your ski when you start getting them high! - expect to see big stress cracks!
if you HAVE to do a big throw... it should look like THE MASTER'S!!! :hail: :hail: :hail: :hail: :hail: :hail:
Mark,
Just go bigger!
Maybe some velcro for your skirt so it doesn't fly up in your face. It must be hard to see where you are going, huh?
Yeah....I'm funny
J/K Mark... just be careful. This trick always seemed unneccesarily dangerous to me.
I dont really understand the throw either. Its not something that can be ridden out of. Looks like a botched trick :dunno:
