Best value shortened turn plate?
madoyster
01/10/08
The Durty South
SJ, I used a UMI turnplate but got rid of the whole bearing set up (It's nothing but a rust trap). It was replaced with a Poly-composite washer that I machined on a cnc router at work. Just like the stock set up.
It works like a charm and I don't have to clean off all the rust/grease.:woot:
Tuscaloosa, AL
freestylegeek said:
Nuh-uh. :bs2:
OOPS< forgot about the Geek Special......... you need to start selling the conversion bolts, they are Moderate Freestyle Tested you know!!!!!!!:Banane01: :hail: :aargh4: :aargh4: :aargh4: :cool2: :cool2:
:cool2:
:cool2:
Tuscaloosa, AL
Rickster said:
UMI with an x-metal -1 bracket is the only way to go.:cool2:
Throw on a x-metal 0 degree bar, and it pretty much makes your steering a -3.:arms:
you have to use the straight bars unless you want to drill out the holes to run UMI Bars.................
arent the bars are extra...
im running a blowsion -1.5 on my SJ with a -2 pole.., and gonig to put a xmetal -2.5 on my fx with a pole I cut down 1 inich.....
sj: -3.5
fx: -5.5 total......nice!
dont forget about the blingin' new throttle pull youre gonnna want with those new bars and plate ;)
i think the most bulletproof setup especially for salt is an Xmetal system with JSS guts on the UMI steering...those needle bearings that come with the UMI suck...JSS has a thrust washer setup to fix that..and its plastic...
wildman326
Who else?
Kansas
Does anyone here know where to get just the straight bars? I think they are like $65 from Pat - which is more than I'm ready to cough up for a 2 foot piece of aluminum tube. The knurled ends might be nice for some grips but they are no help with ODI lock-ons.
ketsair
ISJWTA Member #1
the welding supply store:biggrin:
Yamah0
XFT
Dubai
Dude.. ATP hands down... U can use str8 bars or angled bars and no bearing to grease and mess with..... I would strongly recommend some girlfriend ass kissing and include the ATP nozzle with it... ull be more than happy.
Thats what i have and i couldnt ask for anything better!
Zane...
QJS
X-
GONE
Frayze,
You need to keep up to date dude, that problem was fixed monyhs ago. Been lots of changes since you went into hibernation:biggrin:
Chris.
Tuscaloosa, AL
Call pat up and tell him who you are, (One PWCtoday.com) he cut you a break
they worth it.
