Best power plant for a freestyle 750sx?
FreestyleFreak
Region 7 AM Freestyle
motor
So i should get a motor out of a sxr everything will fit right into my hull?Will 750 electronics work on the 800 motor?
Crab
thanks darin...noswad!
Seattle
Yes to all 3, but you can make the 750 hit just as hard or harder by letting Group K convert it to an 850cc.
aof13
Sfl free since 3/28
Big pin cases and crank
92sx cylinders.
Porting by ______
Single 46 carb
Factory wet pipe
skat prop (pitch depends on what mods you have)
msd enhancer or total loss.
small pin crank and case (lighter) 92to94 sx cylinder with proper porting or stock Xi cylinder. ADA head ,dual 44s, wet pipe.if 93 then use advance plate.
BlueBreadTruck
X-2? Yes please
Cape Cod, ma
whats good about the ss-xi cylinder? I just got a 750 out of one for my x2 and was wondering how the porting is set-up.
227
Its all about the surf!
Oceanside, CA
I'm pretty sure the SXR 800 cylinder should bolt right up to your 750SX bottom end. I slapped an SXR 800 cylinder on my 750 SXI bottom and it bolted right up-no mods needed. I even used my 750 head. I have a SJ with a b-pipe and both skis are about equal in power.
FreestyleFreak
sxr cylander to 750 bottom end
So a sxr cylanders will bolt directly up to my 750 bottom end?And i can use a 750 head?And a 750 crank?
SuperJETT
none
The ss-xi is a different model, he's talking about the old Xi. There used to be a single carb SS and a dual carb Xi version, then later the Xi-R and SS-Xi.
#ZERO
Beach Bum
Florida - U.S.A.
A big bore flat top Yamaha 62T/61X setup would be the best freestyle power plant.
At least you will be using the Wiseco Kawasaki pistons. :biggrin:
